#179279 - 15/09/2003 13:17 What is "deterministic network enhancer"?
ShadowMan
Loc: Newfoundland, Canada
Hey all... just looking through my dial-up settings and I have noticed that this new item is listed in the properties for my dial-up connections.
What is it???
Deterministic Network Enhancer. I can't find any description of it on google or Microsoft's website.
Anybody have a clue??
Thanks!
12 gig empeg Mark II, SN: 080000101
30 gig RioCar SN: 30103114
My blog
#179280 - 15/09/2003 13:21 Re: What is "deterministic network enhancer"? [Re: ShadowMan]
Do you use a VPN?
Try putting it in quotes when searching in google.
#179281 - 16/09/2003 06:42 Re: What is "deterministic network enhancer"? [Re: Phoenix42]
ShadowMan
No VPN at all here, just a slow dial-up internet connection.
I did use quotes in Google but I still couldn't find an actual description of it. Just a bunch of pages saying to make sure it is checked for certain VPN setups and various schools and businesses.
What is it and should I have it checked or not? Will it cause problems with dial-up (as I am experiencing horrible useage problems that my ISP can't seem to find)?
Anybody???
Thanks!
My blog
#179282 - 16/09/2003 07:32 Re: What is "deterministic network enhancer"? [Re: ShadowMan]
JaBZ
Loc: NZ
We use the Cisco VPN Client at work, which adds the Deterministic Network Enhancer miniport driver.
Check if you've got a VPN client installed ones which use DNE are Cisco, Safenet, Unity, Borderware...
You should be able to go into TCP/IP properties of the network connection and un-select it. Also try disabling any VPN services you find in cntrl panel --> admin tools --> services.
Sometime VPN clients may give you connection problems to your ISP due to setups etc... however it shouldn't affect performance.
cheers,
Jai
#179283 - 16/09/2003 10:11 Re: What is "deterministic network enhancer"? [Re: JaBZ]
ShadowMan
No VPN clients here. We simply use the net for email and web access. I am using XP Pro so I wonder if this got added with a update from MS's site.
I have it disabled now but I am not noticing a difference. I'm still having trouble sending emails. FYI, Cancom sucks!
Rene
P.S. This has been a very pittiful ISP expecially since Blaster hit!
P.P.S. We may have land based broadband by Q4 2004.
My blog
